dukalmighty
- Aug 26, 2013
- Threads
- 1
- 8
I removed and cleaned the carburetor by spraying it out with carb cleaner,the float needle was gummed up and stuck once I got it out I cleaned it up until it was moving freely.The problem is when the mower starts it will run on like 1/2 choke or on lower idle speeds,but at medium to full throttle will die out,I'm not sure but it may be flooding out,what do I need to do to fix it,pics would help.Thanks Steve
