Poulan Pro 17 HP 42" Mower Question
2pups
I am looking for a winter project to fix up , and ran across this Poulan mower . It has a couple issues with it . I am curious to know what a good offer to give to owner for this mower is as it sits . Here`s the curent owners description of the mower and a picture of it .
For sale is a Poulan Pro 42" Lawn tractor that needs some TLC. it has a 17HP Kohler Command OHV engine on it that will run. the carb is off and is junk. I had the motor running recently and it sounded good. 42" deck looks in good condition. engage cable is bad. it has a hydrostatic drive that I was told worked fine but heve been able to test it. body and tires in very good condition, RH front has a very slow leak .
If anyone could tell me what a good offer for this mower would be , it would be greatly appreciated .
Jeff
looks like a good deal inthe 150 to 250 range. the belt might be 30 bucks. i dont know how much the carb would be for it though.
Jeff
I agree with Metz's low number at about $150, no more than $200. A basic kit cost about $30, kit with gaskets about $90, new carb is about $125 and with gaskets add another $30. Even if the motor and transmission is no good, you could get you money back by parting it out.
i could probably part the thing out for 300 thats why i said 250. personally if i had to push mow my yard and i had the opportunity to buy that for 250 then i would. i could sell the deck for 75-100 easy.
I would buy it for parts
At $250
If you use the four tires that look close to new.
Put the seat on a mower with a bad seat.
Use the deck spindles on one of the 500 other mowers they fit.
Now your over what you could sell it for if you fixed it
Thanks guys , your input on the mower was very helpful , I offerd the guy 150 for seeing that he doesnt know if the hydro works or not . Still waiting for a reply from him .
Jeff
