need-for-speed
Mine is an SS 4260, 2 years old. I'm pretty sure the (blade / rotor) hubs can't be greased. Has anyone ever drilled and tapped them and added grease zerts ?
Ok this has been a topic on here a lot.
I always buy my bearings at napa.
Was out citing grass with a mower I have not used in about a year it started making noise so went to get bearings at napa they did not have them and sent me DALTON BEARINGS. Couple miles down the road.
Got my six bearings and told the man I install grease fittings in all my spindles. Ha ha he said that's why you go threw bearings so fast.
So standing there looking like a fool a ask WHY.
The bearings are sealed now you put grease in the spindles ( if you put to much )
It pops the seals.
The spindles are not water tight and let in moisture and dust or small particles of dirt/sand
That mix with the grease and wear on the bearings.
Now I know someone will call bull crap
But this man is mister bearing so I will go by what he has told me.
Last week I would have told you yes fill it up full of grease. I would have been wrong.
Cars, An interesting explantation and warning. We are still left with the alleged "part seal" or perhaps "shield seal" which can be and ?expects zerk lube. I am not experienced with tractors,but have asked the questions here about spindles and hubs. I have over the years pried away many sealed bearing shields cleaned, lubed the bearings and reassembled them. Not a big deal...e.g. alternators, motors, vacuum cleaners, generators...usually when they scream at me. There are some bearings with seals and metal shields which are like armor. A while back I asked for more information from two fine gentlemen on this forum who seemed expert, but did not reply. The more info we get the better. Motoman
PS. I wish your bearing man could explain how grease lifts out those seals as they must be pried out , but with only a little effort. I would think the injected grease would simply deflect and create a big glob in the housing, without lifting the seals. Maybe running amok with air pressure guns? Also how does a zerk let water in, not through the spring loaded ball?
I have a ATV that the rear hub had sealed bearings which would be the same set up as your spindles. This unit sees a lot of mud and water and the bearings had a short life span. What I did was to remove the inner seals and installed a grease fitting. I now keep the bearings full of grease and since I have done this I haven't had any more bearing problems. You would have to be careful not to blow out the outer seals when you grease it is all. Personally if it was my mower I would leave the sealed bearing alone and not worry about greasing them unless you are having a lot of bearing troubles.
