How to remove PTO cable from deck on 2013 Bronco mower
rrman
I am trying to remove the deck on my 2013 Bronco and ran into a problem I need some advice on. The manual says to remove the PTO cable from the rear of the cutting deck by removing the hair pin clip which secures it. I had no problem removing the hair pin clip, but don't see how the cable can be removed. Is there some trick to it that I haven't figured out maybe? I can't see how removing the hair pin clip helps with removing the cable. Help!!! Hopefully someone here with more knowledge than me can give me some advice.
It should allow you to pull back and wiggle the cable plastic out of the metal holder, and move it forward and wiggle it out of the hole that the cable is attached to. If you need more specific help, post the tractor's model numbers off of the tag under the seat.
Some of the mowers also have fingers that stick out where the hair pin clip was also. they may need to be depressed to pull the cable out of the mount.
Thanks for your prompt response. I've tried every which way to wiggle it free, but no luck so far. The tractor model is 13YX78KS011. It's probably something simple, but guess I'm too dumb to figure it out. Sure appreciate any help you can give.
I don't see any fingers, but it appears that it needs to be rotated to remove, but I can't figure out how to do it. I took a picture of it and am trying to include it here, but not sure how to do that.
