greynold99
Rivets,
I think you may be on to something with the looking for a crack or loose fitting hose connection in the fuel line somewhere. The fact that once the tractor cools off and then starts right up for another hour or so of mowing would suggest something heat-related... Plus the fact, I've already replaced the ignition coil would to me be more reasonable than a carb-issue.
When you talk about the 'pulse line' which section of tubing are you referring to? There seems to be 3 sections: flexible rubber/pvc tubing from gas tank to fuel pump; a small section of tubing connecting the outlet-side of the fuel pump to metal-tubing that goes through the engine section (under the cover where I can't see) to a piece of flexible rubber tubing on the opposite-side where the metal tubing comes out to the carburetor.
Also, it's interesting to me that there are at least 3 other issues being reported on the forum with similar issue for these Series 2000 Cub tractors of the about the same age.
Thanks for replying and sorry I didn't pick back up on this to respond earlier.
Greynold99
Greynold99
