mechanic mark
Whether you have a new lawn or garden tractor or you've had your tractor for a while, it is very important to grease gears every time you perform maintenance. I purchased my tractor new three years ago from a dealer and nothing had been greased. It's a good idea to look it over before bringing a new tractor home. You will have metal grinding against metal if grease was not applied. Use lithium grease on steering shaft gears and grease them thoroughly. If they have never been greased you will notice a considerable difference. My suggestion to all manufacturers would be to incorporate a cover over steering shaft gears with an external grease fitting, this would keep dirt and debris from clinging to greased gears. If you are, or have a friend that is good at fabrication, you can make your own cover. Just wanted to point this out, thanks.
