beg
- Aug 7, 2013
- Threads
- 49
- 244
I have been working on a lawnboy 5237 here is what has been done so far carb and tank cleaned new condensor lower crank seal replaced, ports cleaned mower has spark and is getting fuel.mower will run but at a slow speed only the governor seems to not work and the hi low speed lever is not moving the assembly.Is this due to a weak governor spring?The motor will not rev up I have at least 10 hours into it and am totaly obcessed with getting it to run.where do I go from here?oh yeah the upper crak seal appears to be good.
