Displaced in the Desert
I have a craftsman mower, walk behind that has been fine up till now.
Today as I was sidehilling with the carb on the downhill side it starts spewing gas out the air filter and shuts down
I let it dry out, restart and while mowing with the carb on the uphill side or on the flat, it is fine, switch over so the carb is down hill and it starts to run poorly, gas comes out the little tube in the air filter ( I removed the air filter to see where the gas was coming from) then it dies. Takes several pulls to restart unless I let it set for a couple of hours.
What do you think the problem is?
Float stuck? Should I give it a technical tap with a screw driver handle?
Is it more than this and going to require the carb be taken off?
