On my '03 LT2000 (917273140) when I engage the blades there's quite a racket from the left blade rotating assembly.  On the odd chance the racket subsides my mower sounds like a smooth purring grass cutter.  The rest of the time the noise is quite loud and I'm getting tired of it.  I checked the blades bolts and they were on pretty tightly, but the left blade had quite a bit of play in it.
Looking at the online diagrams it would seem the deck mower bearing or spindle bearing could be at fault. Should I replace just the bearing or the entire assembly (using p/n 137646)?
Does the play necessitate replacing either the idler pulley (173437) or the flat idler pulley (110485X)?
