Carb rebuild
wink
Hi everyone ,Im new here and just love this place!!
I am looking for visuals or instructions on how to rebuild a carb, Its a B&S engine 126t02-0675-b2. Thanks for any help.
Take carburetor apart. As you take it apart lay out parts so you know how it go's together. If things are gummed up bad from old gas see if you can bring it to a service shop and will see if they let you put it in their carburetor cleaner over night. If not just get yourself a aerosol can of carburetor cleaner and clean the parts the best you can. use compressed air and blow out all the ports and holes. I use tag wire and clean out all the real small holes. You might want to buy a over haul kit which will give you new gaskets and the most important replacement parts. Then just put things back together as you took them apart.
Thanks, I have an over haul kit on the way.
As far as carb cleaner in an aerasol can goes, I like the 2+2 stuff the best over stuff like Gumout or the generic parts store stuff.
I have found that the carburetor cleaner in the aerosol can really doesn't work that well. Is that the brand 2+2 ? Just where do you buy it because I will give it a try. This is the reason I let the real dirty carburetor set over night in a commercial type carburetor cleaner which is a lot stronger. When I take a carburetor apart and it doesn't look very dirty inside I just rinse it out with the aerosol can cleaner and compressed air.
Take picture of the carb before you take in off so that you know where the springs connect to.
