New Rider Suggestions
Tundra5.7
Looking to replace my 16 year old Sabre riding mower. It has served me very well but it is starting to have some issues. Looking for some suggestions on a decent rider. I mow just a bit less than 1 acre. Usually side discharge but will occasionally use a bagger. I do use a bagger in November and December to get up leaves. Looking for at least a 42" cut, any suggestions?
You will probably get a lot of different answers on this but I love my YTH24K48 fast tractor from Husqvarna. I have over 35hrs on it and other than my stupidity when I hit the water valve cover I have had no problems. Great mower, plenty of power and fast. At 7.4 mph you can cover a lot of ground with a 48" deck. And don't let a lot of the Kohler engine stories steer you away from these engines. I think 95% of the issue's were with the single cylinders wich they have since fixed.
I personally dont like kohler courage engines. my craftsman (which i love) is a kohler command (20hp). i love that motor. nothing has gone wrong with it. i would and alot of others would rather work on a briggs and stratton. but alot of the bigger names are changing to kohler like cub cadet, husqvarna, john deere all of those. i think ariens and craftsman use briggs.
Thanks for the replies so far. It seems the weak link in the sub $3,000 tractors are the hydro transmissions, specifically the TT K46. Doesn't the Husqvarna 24K48 use a heavier transmission? Do the mandrels have grease fittings? I would prefer a Kawasaki engine but don't have a problem with Kohler or B&S.
Ariens uses the Kohler Courage except for the Zoom 34.
Lawn Tractor
Yes, the YTH24K48 has the K57r from Tuff Tq. It is a beefed up version of the K46. You can go to Tuff Tq's web site and look at the difference.
