twoguyswithmowers Member Joined Jul 12, 2013 Messages 27 Jul 29, 2013 #1 There is a bar at the rear of my zero turn. Is there any reason that I couldn't sleep and anything up on its rear? It would make it easy to change the blades and clean underneath the deck.
txzrider Well-Known Member Joined Apr 24, 2012 Messages 392 Jul 29, 2013 #2 snapper riders(or at least mine was) are designed to do that.. but the oil fill tube is in the back of the mower to allow it.
twoguyswithmowers Member Joined Jul 12, 2013 Messages 27 Jul 29, 2013 #3 This is a gravely zt 34 if it makes any difference
txzrider Well-Known Member Joined Apr 24, 2012 Messages 392 Jul 29, 2013 #4 Then I would look at your owners manual, it will state if it is possible to do it, if no mention then I would not.
twoguyswithmowers Member Joined Jul 12, 2013 Messages 27 Jul 29, 2013 #5 Assuming that I cannot… What is the best way to get under there? Car ramps?
lawn mower fanatic Lawn Pro Joined Jun 8, 2012 Messages 6,749 Jul 29, 2013 #6 twoguyswithmowers said: Assuming that I cannot… What is the best way to get under there? Car ramps? Click to expand... Or mower lift.
metz12 Well-Known Member Joined Nov 24, 2012 Messages 892 Jul 29, 2013 #7 or put it on car ramps? then put a cinder block behind a wheel just encase it doesnt roll back on you.
R Rivets Lawn Royalty Community Leader Joined Mar 11, 2012 Messages 16,280 Jul 29, 2013 #8 In our shop we just put a car jack under the front of the deck and raise it up. Do it everyday with no problems.
twoguyswithmowers Member Joined Jul 12, 2013 Messages 27 Jul 31, 2013 #9 Couldn't find anything in the manual so I emailed gravely. They said do not stand it up on its rear
Ric Lawn Pro Joined May 7, 2010 Messages 5,765 Aug 1, 2013 #10 The Mojack EZ. You can get one at Tractor Supply right now for $99 http://www.tractorsupply.com/en/stor...t?cm_vc=-10005
