Cant get engine to rev up under load on Craftsman WeedEater
MOmilkman
Hi guys,
Ive had a problem with my weed eater for some time now and I can not stand it anymore. Its driving me crazy and I have to get it fixed.
The model is Craftsman 358.791070 - 32cc 2 cycle Weedeater
It will idle fine, no problems there. But when you give it a gas to try to rev it up to trim something it will immediately try to die (or will die). Gas is only about 2 months old. (manual says use gas no older than 30 days but I call BS on that)
Under the troubleshooting section of the manual it says-
Trouble
Engine will not accelerate, lacks power, or dies under a load
Cause
1 Air Filter Dirty
2 Spark Plug fouled
3 Carb requires adjustment
4 Carbon buildup on muffler screen
5 Compression low
I dont believe it is 1, 2 or 4. All those have been checked or replaced since problem started.
I dont think its 5 but not 100% sure.
I think its 3 but not sure what to adjust.
In the picture you can see the carb on the weedeater. I know the one screw (largest one at bottom) is the idle screw. Other than that no idea.
Can anyone help?
Thank you
Hi guys,
Trouble
Cause
1 Air Filter Dirty
2 Spark Plug fouled
5 Compression low
Can anyone help?
Thank you
Buy a new carb. Or a new weedeater....
Hi guys,
Trouble
Cause
1 Air Filter Dirty
2 Spark Plug fouled
5 Compression low
Can anyone help?
Thank you
You need to buy a special screwdriver to adjust the mixture screws.
Mine takes the 'Pac Man' type, so-called because the needle valve head is just round with a pie-shaped chunk out of it. After receiving the tool, I had the thing straightened out in two minutes.
After getting it started, use it until it's completely warmed up. I use mine with a blower attachment which is why I'm using it in the fall/winter. Leave it idling and put the tool on the LH valve, or Lo-speed, and turn it left to enrich the the start/idle circuit. Turn it until the engine speeds up and then begins to slow down. Now give it full throttle and do the same to the Hi-speed side. Open it up until it begins to '4-cycle' then close it a little to get your top end back.
Thx impalass. I'll have to look into buying that special screwdriver. I noticed those two adjustment screws at the top in the picture and wondered if that played into it. I'll let you know it turns out
MO, search in this forum for the diy and adjustment of your machine. Look for "trimmer speed and spark tool" I have a 31 cc unit about 6 mos old and both lo and high speed circuits required adjustment. Save yourself $25.
Thanks motoman! Will do!
