n2omichael
Hi Guys!
I have an older STX 46 (black deck) tractor, while cutting the lawn yesterday the mower just quit? The tractor itself kept running fine, there was no belt squeal or burning smells, it was as if I shut the mower switch off, but, I didn't.
I shut the tractor off and had a look, belt is fine and blades turn free. I did notice one difference, before if engaged the mower with the tractor not running, but, with the key in the "on" position you could hear a distant click, like a relay or solenoid? Now there is no clicking.
I checked and the 2 wires going to the clutch assembly seem to be firmly attached.
Is this a common issue? Switch? Wiring? Or a relay maybe?
ANY input would be appreciated, I would like to finish cutting the lawn!! HA HA
Thanks Guys!
Michael
Thanks Guys!
Michael
