Scotts lawn mower selonoid
Mikte
Hi everyone, I've got a 99 scotts 16 hp riding mower that I put away for a while, now I'm trying to get it ready to sell. I've got a buyer but he wants it running so he can drive it home, I did not think that was going to be a problem because it ran fine before putting it up, and yes all the fuel was removed before storage. We can not get the tractor to turn over unless we short the selonoid with a wire. I now there are general use selonoids available, the problem getting the old one out, it looks like its got two bolts coming up from the underside of the frame that you cant seem to get to. I'm sure that when they put this thing together it was floating down the assembly line upside down without ever a thought of what to do if this broke? Is there anybody out there that knows an easy way to replace this thing?
WELCOME to these Forums...
I am so against replacing good parts with 'new' parts... I have to ask, when you say you shorted the starter solenoid, what did you do?
ON the Starter Solenoid:
1. short from one Large terminal to the Other Large terminal.
or
2. Short from the Large terminal (from the battery positive post), to the Small terminal.
I am only curious as to what one of the above methods you used...
#1 can determine if the starter is good.
#2 can determine if the solenoid is good.
:smile:KennyV
Thanks KennyV I now know I have a good starter, I'll try 2nd option as soon as I get the chance. Mike
or
:smile:KennyV
