electrical problem IS5001Z
rmil92
I have a IS5001Z cat diesel. I was mowing and both lights came on on the dash. now pto won't come on unless I pull the relay out and only partially reinstall it then pto will engage until I push relay all the way in and will go off again. I have double and triple checked connections on relay and they are making good connection. there is some type of module I believe has something to do with the pto could this be my problem. any suggestions?
Test wires going to relay for power with relay partially inserted, then test with relay fully inserted.Test relay female plug for power. Use jumper with a fuse and check the wires leading to the plug for power. gregjo1948
