Saddle Tramp
- Jul 9, 2013
- 9
Just go through the section on how to adjust the governor.
Well, that took care of it. There were some hints in the manual that I hadn't seen in other on line suggestions. Runs great now, but when I went to push it out to the yard, the rear (drive) wheels are locked up. Since it's not running and the handle is not pushed down to engage the drive belt, I'm guessing I will need to remove the transmission/drive assembly to see what's got the gears locked up. Before I took that all apart (and the manual is going to be a great help there) thought I'd check to see if you had any suggestions.
Thanks again for all the help so far.
