I want to know what zero turn comercial mower I should get for a good price
Still say Kubota. There are lawn mowers and then there are Kubotas. Kubota is like a tank.
Kubota is a good mower but Just because it more expensive doesn't make it a better mower, and your right there built like a tank the problem is they also weigh as much as a tank. The normal 60" mower (Toro Z-Master 5000 / 60") is going to tip the scales at around 1200lbs the ZG series Kubota goes around 1700lbs. Kubota is like the JD they make some great farm equipment but there mowers fall way short IMO.
