thegreaneys
- Jul 10, 2013
- 1
As soon as the mower is started the blades start running, the PTO switch on the dash is in the off position. If you pull the PTO sw to the on position the blades stop. I've replaced the vacuum actuator and the vacuum solenoid. The condition still exists. I've checked the state of all the switches in the static state, no power on mower not running. They all check out opens are open closed are closed and when the sw's are actuated the opens close and closed open. I'm looking for any suggestions as to what could cause this problem.
Regards,
Patrick
Regards,
Patrick
