hanyoukimura
Well here it is, finally a proper introduction to my Jacobsen 32164. As of yesterday it is now in working order and successfully cut my front lawn. The engine runs fantastic. Starts in 2-3 pulls when cold and first pull after warmed up. Runs smoothly with no smoke, and is surprisingly quiet. I have yet to figure out where/what the serial number is for the Briggs engine, so for now I shortened the throttle spring that was on it, which was far too long to be useful, and adjusted until I got it functioning like it should. I also had to ad a washer to the front right wheel arm to take out the excessive play, so it would stay locked in place. There was so much play that the arm and wheel would come out of lock and flip all the way over! It's still got play but at least now it stays locked in place.
My biggest problems for this machine will be getting new wheel arms, all of them have a lot of play because the metal tabs that keep them locked in place have worn down, and getting new blade for it. I can't find any information or parts for it anywhere, or even info on how the blades are supposed to be attached. When I pulled them off, the smaller blade was on top of the large one, with the sharp end facing the opposite direction. Makes no sense to me. Is it supposed to be like that? Making the sharp edge face the same direction as the main blade isn't possible because it won't sit level on top of the larger blade, so I put it under the main blade, facing the same way as it. No idea what the correct setup is, but it mower the grass well!
Anyway, here's a bunch of photos as it appears all together and running.
Meanwhile, a neighbor brought me his Craftsman 917.374430. First thing I noticed was a nut on one of the engine mount bolts. He said the deck was cracked. He complained that it leaked oil. He thought it was the crankshaft seal and wanted me to install it. I told him I would look at it first and then give him a price.
First red flag was that nut, second was oil on top of the deck, and under the deck, but not around the crankshaft itself. Sure enough, as I pulled the engine off, I found the oil leak. The deck wasn't cracked, the base of the engine was where the mount is!
Also the drive belt is broken and the front wheels are loose.
Meanwhile, I ave another Craftsman I was asked to look at. This is a 917.378980. Same deck as the 917.374430, but this has an Intek engine and is in much better shape aesthetically. I have yet to look at it, but the recoil is broken, the blade brake cable is seized, and it needs carburetor work.
