My Lawn Mower Repair Thread (56k warning)
Finally a break in all this rain! Of course it was very muggy and warm, but at least i was able to get some work done.
Well the little Poulan that smoked a bit finally sold.
Today was a pretty productive day. Had a look at a neighbor's Craftsman. He dropped it off a few days ago saying it would leave a puddle of oil on the ground. He mentioned he had put a bolt through the back mount with a nut on it to hold it to the deck because the deck had cracked. He thought it was the crankshaft seal on the Briggs Quantum and had bought a new one. However, when I first looked at it that day I noticed oil on the back of the deck and under the deck but there didn't appear to be oil on the crankshaft. My suspicion about the leak was confirmed when I as I was pulling the engine off. It turns out it wasn't the deck that was cracked, but the block of the engine itself was cracked. In fact the mount was broken away from the engine, leaving a hold for oil to leak out of. He's deciding what he wants to do with it.
Afterward, I finished rigging up a homemade BBC cable for the Ariens so I could see how it ran. The cable actually looks fairly legit, I'm pretty pleased with it, although I will probably still go buy a new OEM cable...seems the one I need is actually about $20 so not bad. I'll get pictures of the setup tomorrow.
I also decided to finally tinker with the Jacobsen. The exterior of the carburetor and tank were nasty, but the inside wasn't too bad. Cleaned it all up, rinsed teh tank out and cleaned the carburetor and it fired right up! needs a throttle spring, but it will run really well without it, just at low idle.
I also finally played with this Craftsman I've had for over a year now. gave up on the finicky carburetor and swapped it out with another one, put a shroud on that would accept the tank I have for it, and it too fired up and runs well.
I always enjoy reading these updates. :thumbsup:
So the Jacobsen just needs a throttle spring and it will be a good running mower? If so, that sounds good. Do you have an estimate for how old it is? I'm guessing early 1970s -- but that's just a guess. There should be a number on the B&S engine which has a year code -- I think. There have been threads that touched on that.
Keep up the good work.
Yep, it runs great, really happy about that. Which means I'm planning to restore this and keep it for myself.
I have tried to find a number on the engine but I don't see it on the shroud. Where else would it be on these older Briggs? I can't find the year, or really information on it. The model number is 32164.
I don't know but you might try searching for a thread that talks about this. There's no model number on the deck... right?
There's the model number of the mower on the deck, not the engine, but the mower's model number doesn't seem to be helping since its so old!
Here's a photo of it today.
I also snagged a photo of the Craftsman. It's finally running well with the new carburetor.
I'm not sure what to do with it yet. On the one hand, I don't need yet another mower, but on the other these Craftsman are becoming increasingly uncommon, especially one as clean as this.
Here's some better photos of the Ariens, I've already done some touching up of the paint, the only areas left to touch up are the caster wheel frames and the area under where the bag sits.
Oh, and here's my temporary cable repair so I could get the engine running. The sheath was still good, so I got some 3/32 cable, a thimble, some ferrules, and a cable stop. I don't have a swage tool so I had to make do with vise grips to clamp the ferrules down, but for an idea I came up with on the fly and something I've never done before, its not bad.
Yeah, The Ariens can go so fast-- you practically need to jog to keep up with the thing.
Although Parkmower may be saying of all the craftsman he has owned or tested... it was the fastest craftsman he has seen.
When I sold the first Ariens I actually told the guy it can go anywhere between crawl and jogging speed. :laughing:
