rsowersby
I am new to this forum and new to diy mower repair, so I don't know much. I own a Craftsman Lawn Tractor 917.28851, 21.0 HP, 42" mower, about a year old. It has worked great for us until this problem came up.
The mower runs and drives fine, but the blades don't engage when the lever is moved. As far as I can tell, the belt is still good, and the idle pulleys and the blades turn as they should when the deck lever is disengaged. What else should I check and how?
Thank you
Thank you
