BrokenTiller
Ok, I'm going to give as much information as I can, but unfortunately the details will be somewhat limited. The back story is that my grandfather's tractor died last year, so my dad put a motor on it from an identical model tractor that ran fine when parked (deck rusted away, and tractor generally rusty and in poor condition from sitting outside). I don't know specific model numbers of either the tractors or the engines, but they are the Home Depot variety John Deere Sabres with Briggs and Stratton engines (either 38" or 42" cut), probably 10 years old or so. Again, I apologize for limited information - I live about 2 hours away from my parents and grandfather.
Since switching the engines, the tractor runs fine at an idle - I mean perfectly smooth - and will drive around the yard fine, but after mowing for a few minutes (maybe 5-10 minutes typically), it will start to kind of surge/sputter and want to shut off. Sometimes it can be saved by putting it in neutral, disengaging the blades, and playing with the throttle to keep it running, but other times it shuts off completely. Usually, even if it is kept running it will continue to sputter/surge even in neutral with no load on it for a while. Sometimes it will straighten itself out after a few minutes, other times as you back the throttle off it will die. If you let it set for a minute it will fire right up and idle perfectly smoothly again.
They've put fresh gas in it, cleaned the carb, switched carbs, cleaned again, and switched back again (cleaning with every switch), and tried 3 different coils (one was bought new). When you pull the gas line off there is good fuel flow so the line/filter isn't clogged (he had tried taking the in-line filter off though, in case that was the problem). When he starts it, he can usually drive around the yard perfectly fine for a while at high speed, but if he turned the blades on, it will start to surge within a few minutes (not an immediate response). Going up hill seems to be worse than level/down hill. They've been tinkering with this thing for several weeks now and just can't figure it out...
Thoughts?
Thoughts?
