MowerMike
- Sep 5, 2012
- Threads
- 85
- 964
I have three electric chainsaws:
1) Greenworks 10" 20V Li-Ion battery powered
2) Greenworks 12" 40V Li-Ion battery powered with sprocket tip bar
3) Homelite 14" 9A corded electric with sprocket tip and safety tip bar
I really like the 14" bar with the sprocket tip and safety tip bar, but don't like dealing with the cord. I really like the Li-Ion battery powered chainsaws, but would rather have the larger bars with safety tip on the 40V chainsaw and sprocket tip on the 20V chainsaw. So I decided to see if the bars were interchangeable and it turns out that they all are. So I rotated them out as follows:
1) Installed Homelite 14" bar on Greenworks 40V chainsaw
2) Installed 40V Greenworks 12" bar on Greenworks 20V chainsaw
3) Installed 20V Greenworks 10" bar on Homelite chainsaw
I also changed out the stock skip tooth chains on the 12" and 14" bars with new Oregon standard chains that effectively increase the chain cutting speeds by 50%.
I haven't checked out the Homelite, but the two Greenworks Li-Ion chainsaws work perfectly. Interestingly the 20V Greenworks chainsaw with the 12" bar and smaller capacity battery weighs more than the 40V Greenworks with the 14" bar and larger capacity battery. Both chainsaws will run under load for over 30 minutes on a fully charged battery, and I have two 40V batteries, so I can do up to one hour's work with the 40V Greenworks.
