mrseedsower
I have a Snapper riding mower with a 11.5 hp motor. We just got the motor running again and now it will only drive in 1st gear. In 2nd gear or higher it just sits there. I thought the rubber drive disk that contacts the drive plate on the engine shaft was worn, but it looks fairly good. However the drive plate on the engine shaft looks rusted. I know I can adjust that plate up and down but how can I clean the rust off of the drive plate without totally disassembling the mower rear end?
Is there an easy adjustment to adjust the drive plate with the rubber drive disk so this will work or do I need to clean the rust and somehow fix the rubber plate. Any help here will be thankful.
Blessings!
Richard
Blessings!
Richard
