Brucebotti
You will find that in time that you will be making turns without giving it a thought and it will not take long. I can't count the number of hours I've put on ZTR's over the years but I can tell the hours really don't mean anything because or regardless of how many you have or how good you think you are you can still tear up the turf. The thing is there are so many things that determine how to maneuver or handle a Ztr like the conditions, Hills or slopes, is it dry, or wet, cutting height of grass, type of grass, are you mowing on sod, Bahia, Bermuda or some other type of grass all and more play a part in how to use your ZTR.
Thanks Ric,
As usual your advice is spot-on. I am trying get up to speed and avoid picking up any bad habits that may harm the lawn or the ZTR. I am having a lot of fun learning.
Bruce
