question about nikki carb.
roswald22
can someone tell me the significance of the area indicated by this arrow?
Would a there be a reason for a buildup of yellow gunk.
Thanks Rick
Thanks Rick
if you are talking about the little right welch plug. that is the cover for the transition ports for fuel flow on the idle circuit of the carb. Yellow buidup could be sealant installed at the factory.
