John Deere 425
lorens
I have a 425 john deere and all of a sudden it will not start checked the battery and cleaned the posts but starter will not work does not click or anything.
You should probably get a wiring diagram and check the starting system with a continuity meter. There's several switches and modules on the 425 and if defective will result in nothing happening when you turn on the ignition switch.
