G GX255 Forum Newbie Jun 2, 2013 #1 17hp Kawasaki engine doesn't reach full rpms when deck is engaged. deck appears to turn free when belt is loosened.
PJ Well-Known Member Jun 2, 2013 #2 GX255 said: 17hp Kawasaki engine doesn't reach full rpms when deck is engaged. deck appears to turn free when belt is loosened. Click to expand... what is the condition of the three blade carrier bearings. listen for noisy bearings, track pulley noises and belt slippage could be the cause. PJ Sent from my iPad using LMF
G GX255 Forum Newbie Jun 2, 2013 #3 Thanks I checked all that even tried a known good other deck. Same results.
PJ Well-Known Member Jun 3, 2013 #4 GX255 said: Thanks I checked all that even tried a known good other deck. Same results. Click to expand... This means the engine has a lack of power problem. needs a good tune-up perhaps like carburetor cleaning and adjustment fuel condition spark plug. I do not know the hours on your engine and its condition? did you do a compression test perhaps? PJ
