What is wrong when the engine won't shut down when I turn off the key?? Someone suggested I put a kill switch on, but I' rather fix the problem if someone knows what is wrong. Thanks!! [email protected]
Normally you will find a kill wire attached to a spade connector underneath the coil as it sits attached on the engine. Unfortunately, you will need to pull the shroud off to get a look at it. Check and make sure it didn't vibrate off or that the wire may have gotten cut in half somehow. Good luck!
