jimswieringa@yahoo.com
- May 28, 2013
- Threads
- 1
- 4
carb keeps flooding out
Sorry its a Weed Eater Twin v 18.5 hp Briggs and Straton. It keeps spitting fuel back up through top of carb. It doesn't sound like a stuck valve in the head.No loss of compression in eather cylinder .Is it possible float stuck in carb? Thanks for any help, and i did have a McCoy 049 in a Stuntmaster airplane when i was a kid.Thanks JimOn your McCoy 049? Or on your Allison V-12
i I TOOK THE CARB APART AND BENT THE FLOAT SO IT WOULD KEEP THE NEEDLE SEATED AND IT WORKED THANKS FOR THE ADVISE. JIM.SI suspect that a good carb cleaning, with the replacement of the float needle and seat, should solve your problem.
