WhyZed
- May 11, 2013
- Threads
- 6
- 109
Rebuilding a 1979 5124
I thought I had a good deal on a preowned LB as the owner/salesman ('Dick faced' liar) stated that he had it for a decade and it worked perfect :thumbsup: Maintained regularly and he was sad to see it go:frown: He got a brand new big-wheeler with a bag and just wanted the little LB gone to make room.
I got it for $20.00 and I think I paid to much :wink:
Just home after a quick jont into the carwash I was so happy with myself.
Then I start rippin into her and find all is not so Rosy.
There are some heavy pock-marks. One goes all the way through, 2 more are all most through. Paints blisterin on the shiny side of the deck!
So I got a plan and put it into fruition.
Glass done
2 coats of rubber truck-bed liner. - sorry Pics later :ashamed:
4 coats of green paint with wet sanding in between coats.
New (old :wink: cylinder) on top of totally disassembled and cleaned crank with new piston and rings.. Oh-Ya
Rebuilt motor with piston and rings. I cleaned 2-3 cups of grass trimmins out of the crankcase!! :shocked:
The reeds were suffed with grass = open! :shocked:
The carbon in the head, piston top, crank, cylinder, exhaust was stupid stupid stupid!! What do these 'people?' use for 2 stroke oil?
What do these 'people?' use for air filters? How do these people get work?
The piston definitely had been seized and he broke it free to sell "not seized!! Mother F-er!!!
The rings were seized into the grooves, the piston pin seized into the piston and the cylinder scored bad!!!
Time for some snacks and a brew er two. I'll see if it fires up tomorrow if I can get back to it.
Ps - the carb was totally STUFFED with vanish and grass. It is the 'Utility' carb and I don't know how to take the main jet out?
Anyone know?
Thanks LB lovers - cheers... :thumbsup:
Glass done
Anyone know?
