Perry
Spring and fall I cut lawns as short as I can keep that dam yellow stuff low low.
Summer I usually cut 3 in some customers prefer closer to 4.
Do you catch the clippings when you do the short-length cuts?
Ric
Do you think you're in the minority or majority? Do many
contractors mow twice a week to avoid bagging all those
clippings? Can the clientele stand that cost? My lawn is
simply too big to consider bagging without a big ride-on
that has a voluminous catcher.
That said, I agree with you. I mow my own lawn twice-a-
week on average. But I'm retired and can afford the time.
Before next Spring, I hope to have a Husqvarana 260/5ACX
automower on the job. I also plan to chronicle the purchase
and installation process/experience elsewhere on this forum.
Returning clippings has - for me - carried another risk. The
incidence of brown patch. But I'm wondering if the cutting
height is implicated in that. What seems to have happened
over the last summer is that the grass has become long
enough to become 'wavy' and lay down. So the blades are
growing sideways some distance, before rising vertically.
I can see that when examining the scuff of my footprint, at
times. It's one of the reasons why I'm trying to drop the
cutting height - to get back to vertical blade development
in the lawn. The newer grass has been more susceptible
than the old part, and the fescue got nailed, but the rye
seemed to recover OK.
Personally I never bag grass, it's time consuming and unnecessary if you are cutting your lawn correctly. Remember the one third rule, removing more than one-third of the grass plant when you mow leaves the grass less resistant to disease and the stress of hot summer sun and weather. Clippings left on your lawn will eventually decompose and recycle nutrients back into the soil, it also helps shade the soil, keeping the roots cooler and reducing moisture loss. Remember grass is 75 to 80% water. Leaving the clippings on the lawn also contributes to your fertilization needs. Mow your lawn more often keeping your grass clippings one inch or less in length lets the clippings decompose quickly and will be more beneficial to or for your lawn and besides you can remove one inch of grass twice a week faster than 3 or 4 inches once a week and it's easier on you and the mower.
