LAWNMAN02556
- May 25, 2013
- 5
I have a Scag Tiger Cub that was running just fine day before yesterday. I went to start it and all I get is a very slight click at the engine. It will crank if I jump the solenoid.
When you say "crank if I jump the solenoid." what do you mean.?
Under the panel next to the keyswitch is the cranking circuit relay, this may be your problem as this relay is known to be problematic.
There is a Scag forum here listed under Brand Specific Forums, check it out.
The click the you hear when you turn the keyswitch on is the fuel shutoff solenoid on the carburetor.
Mad Mackie in CT
When all the safety circuit parameters for engine cranking are met, then the interlock module will ground the start circuit relay and allow engine cranking.
These circuits are, PTO switch, parking brake switch, L/H and R/H lever switches, and the seat switch.
Seat switches and key switches are known to fail, but the seat switch more often.
Both the start circuit relay and seat switch have been replaced on my Tiger Cub. I did buy a new interlock module as there have been problems reported with interlock modules of these part numbers: 481808 and 483029, both of which have been replaced by 483599 which is the one that I have at $109 but the original module, 483029 was working correctly and still on my machine.
With the machine in the full operating situation, the seat switch input to the interlock module is the primary controlling input and when compromised will shut off the PTO, shut down the engine, and prevent a restart until all the cranking parameters are reset.
Mad Mackie in CT:laughing::smile:
Mad Mackie in CT
