BigDaddyFatSack
- May 23, 2013
- 2
Hi everyone. I'm new so be gentle. Lol. In 1990 my grandfather bought a new Task Force I/C 12 HP 38" cut riding mower and gave it to me about 7 years ago. It has a B&S Model 281707 Type 0411-01 Code 89082511 in it. After it sat for about 10 years, I installed a new battery and cleaned out he fuel bowl and it has run like a dream ever since. Until last week. Started it one morning and it had a rough idle. Pulled the air filter and looked into the carb and it had what looked like oil and gas mixed cause it got dark quick. Throttled it all the way down and you could clearly see gas until it was throttled up and it filled up with gas and oil and then cut off. Today I took the head off and could see oil and smell gas on it. Rotated the motor by hand and watched the valves stems to possibly check the valve seats. The exhaust valve had very little on it so I figured it would be blown out anyway. The intake I couldn't really tell due to the gas. A short time later I checked the oil and noticed it wasn't as thick as it should be. Lit a lighter and the dip stick oil lit too. What would cause this ? The only thing I could think of was maybe the valve seats or the piston rings. Any help with this question would be greatly appreciated
