Wheel Horse 616z mower deck ???
qtrhoss
Have a Wheel Horse 616z zero turn with a 42 in. deck. I need a new spindle. But trying to search for parts for this mower is proving to be more than a challenge. Can anyone point me at the right part number or best place to get one?
Post the units model number, located under the seat and I should be able to look it up at work.
Did not find any numbers under the seat. A tag on the frame behind the left rear wheel were two numbers. not sure if either of these will help, but thanks for trying if you can.
Tag says Wheel Horse the numbers are first "Y1 160E01" and "25529"
Thanks, now I just have to figure out which one it is. Thought it would be much easier to figure this out on my own.
Now that I've gotten the deck off which I'm quite sure hadn't been done since new..... None of these look correct. And of course, found where the model / serial number should be..... of course not there. I know, can't expect that a machine this old will be easy to fix. Oh well wish me luck.
Contacted Jacks Small engines and seems this is a discontinued part their suggestion was contact Toro on tuesday, maybe they can help.
