Coca Kohler
I have a husqvarna lt100 which I bought as a project and I got it running after cleaning the carb and fixing some wires. But when it runs it smokes a bit even after start up and it is hard to start. I tried adjusting air:fuel ratio but still no stop in smoke. Yesterday I took the engine housing/cover of to repaint them and when I tried to start it it kept popping from the top of the cylinder head, between the head and the engine block. It was a bit like this before but I didn't notice it that bad. A few of the pops were more like bangs which were very loud which I presume was the fuel igniting and releasing the power out of the head gasket instead of the piston. It has a bit of oil built up around the head gasket but I like to be sure it is that. I'm only 16 so I'm not really an expert on engines yet but hopefully one day. My dad is a truck mechanic and I told him what the symptoms and he said it sounds like a bad head gasket but he doesn't have time to look at it. When I got it I found it full of about 2 litres of watered oil but would that of done damage to any of the engine? The engine codes are Model 254707 type 0140-01 code 9303110. Also what would the torque settings be for the head gasket. I have got a torque wrench which I was given but I am unsure on how to use it properly. Thanks for any help.
