parker wheel motor replacements or rebuild kits
dragracefan
Hello all, I'm looking for info on a rebuild kit or a crossover part number for a parker wheel motor fro a cub cadet, I see these things for about 600 for a scag from different suppliers, but 1100 from cub cadet and no one seems to sell this in the aftermarket. can anyone help me out with a place to get a better price or where I can get a part number cross over. its a 2007 cub cadet tank zero turn, Model m60-kh, 53ah8ctx750. the wheel motor number I am looking for is a right side motor DF0240JSA81AAPA, this number is off the back of the wheel motor. any help would be appreciated.
Here is one source...: Parker Wheel Motor
There are others with better prices, but you will have to buy wholesale, if your set up for that...
What happened with your Wmotor, is something broken internally or is it leaking? :smile:KennyV
it locks up and when you turn it by hand it barely turns, one of the pumps came apart and sent metal thru the system, the guy who owned it did no maintenance at all. I did take it apart and the pump vain is locking up.
I seen that one but I wasn't sure if that number crossed over or not. I can remove the brake assembly from mine and put it on that one, i just need to know if its the same as mine with out the brake drum flange.
Good luck with this.
I have tried twice, and in the end I wasted time and the money on the parts, because some of the major parts were bad that were not in the kit. The tolerances are "very" critical. You will need to get the specs and mic all the shafts, swash plate, everything. Another requirement is "absolute cleanliness" This is why they use a 30 micron filter.
Good luck. It "can" be done, but be sure you clean and flush your complete hydraulic system 2 times. All it takes is "one" tiny little piece of metal shaving, and you are back to the beginning and out your time and money.
Call George at Marathon Hydraulic Motors. They have the parts, specs, shafts, and anything else you might need. They can also repair it for you if you don't have the right environment. Very reasonable. Most rebuilds are about $325 and comes with a same as NEW WARRANTY 1 YEAR. 815-337-3600. They are in Illinois and they have free shipping.
