Pulsa-a-prime carburetor
jeruss
Hi, Guys. Does anyone know how to remove the primer bulb from those cheap Pula-a-prime carburetors. I need to soak the carb. in cleaner and didn't want to immerse the primer bulb. Thank you.
The primer lock ring has a locking tab on each side that have to be pressed in to remove the primer. They are still a pain to remove, even with the Briggs primer removal tool.
Push one side in at a time with a flat screwdriver. Spray a little lubricant on the tabs to help 'em slide out a little easier. Yeah, they're a pain:frown:
