propane
remy
propane on a walk behind mower pros & cons
help and thanks
reynoldston
Didn't know that they made such a thing. It just seems like the fuel tank would be too big and heavy. Is this something you plan on buying or making it yourself?
Size of the carb and tank would be bigger that the engine.
exotion
Camping tank? And a regulator? Propane is already a gas so you don't need a carborator. A regulator will give the right amount of gas. Throttle I am not sure about or choking
KennyV
I have used a LOT of propane on large and medium AG tractors... there are a 'Few' advantages.... BUT the Un-handiness of refilling tanks and the availability of easy fuel sources out weigh All the pluses ... :smile:KennyV
midnite rider
Check out 52waters propane conversions album link here.
Walleteater1
Might be impractical on a walk behind, but what do I know. 20yrs ago when I worked for a propane company they had an old John Deere at the time that ran on propane. Riding mower with a tank on the front of it. If I remember correctly the setup had it running on liqued propane sent through an impco vaporizer or something like that then a carburator.
remy
I've heard they lose about 10% of the HP. If you check "exmark propane" you will find it interesting they do no list HP under "spec's
