how to install a tach on a lawn tractor engine
cuda
Does anyone know how to install a conventional tach on a B&S 24 HP V twin engine?
That is how to wire it up.
Carscw
A tach runs off the coils 12 volt power supply.
Not sure how you would hook one up on a mower engine but I shall do it this weekend and let you know
Sent from my iPhone using LMF
cuda
Thanks carscw, my engine uses a magneto and I'm not familiar with them at all.
As I posted in another thread to my knowledge there are no conventional tachs available for small engines. Tiny tacos are great and easy to install.
cuda
Found this info on youtube. Autometer make a tach for briggs & Straton engines only. Model 6652
Kind of pricey $147.00
kjprrt
Wow I might get that for my walk behind
I have one on my walk-behind and motorcycle (to make sure idle is set right).
Simple, but gives the info you want.
Hope that works for you.
