Vibrations JD 115L
WWJ
When blade is engaged I feel stronger than normal vibrations. Spindels are fine and free of any debris tensioner seems to be fine. Belt looks to be good. Is there any history of this model having issues with the belt stretching??
With the mower OFF grab the blade and see if there is any play or wobble. If there is then grab a wrench and make sure the blade nut is tight.
Look and see if a blade is broke and or bent
