which shall i get?
thx
I've had good luck with the Black & Decker 36 volt lithium-ion battery model LST136. It easily converts to an edger and has a variable speed to increase battery run time. It also has an adjustable shaft length, which is nice if you are short like me. The auto line feed works well and it is easy to charge pre-wound spools.
