HovercraftFullaEels
Hello,
I've been searching Google a bit and have seen some similar problems to mine, but the few solutions I found haven't worked for me. My LT160 won't start. I turn the key, and get no power; the hour meter doesn't turn on, nothing. So far here's the troubleshooting I've done:
-Made sure the battery has power. My charger shows it is fine.
-Tried unplugging the safety sensors to eliminate them as being bad (seat and parking brake sensors). Tried to start after unplugging each one one a a time - still exact same.
-Used my air compressor to blow out the dust from all electrical connections I could find. Figured it would be good to clean them out and re-seat them.
-My neighbor is a retired mechanic and when I started having this problem in the Fall he suggested it was probably a bad solenoid, since at the time you could jump across it with pliers and it would start. By the end of the year it quit doing that even. I replaced the solenoid but still have the same problem. I can now jump across the solenoid and the engine turns over. You can see fuel going to the engine but it never actually catches and starts. If I pour a little gas in the carb it will catch and start for a second, but as soon as I move the pliers away from the solenoid it dies immediately.
-While I was replacing the solenoid, I also did a full tune-up using the JD maintenance kit (fuel filter, spark plug, air filter, oil, oil filter). Probably doesn't have much to do with this issue, but it should at least eliminate the spark plug as an issue (but does this need gapped? I'm assuming it was done already but I'm not sure).
So at this point I'm thinking it's either the ignition switch or the fusible link wire. I've got these and a couple other items in my cart over at greenpartstore.com, but wanted to check with some more knowledgeable people before pulling the trigger on ordering them.
