turbofiat124
- Mar 23, 2011
- 288
OK since I moved into my Grandparent's house back in 2000, I had to purchase new lawn equiptment. Being the frugal guy I am, I went to Wal-mart and bought the cheapest trimmer and leafblower they sold. $69 Poulan Weedeater Featherlite brands.
13 years later the weedwacker still starts on the 3rd or 4th pull. The starter mechanism on the leafblower is worn out (cord won't retract at times). After four times, I got tired of taking it apart reloading the spring (PITA) I decided to just buy a new Poulan leafblower but the engine is still good on the old one. Maybe I can transplant it to the weedwacker if it ever blows or sell it on Ebay for parts? I also bought one of their hedge trimmers which I really like although might I suggest do not get it anywhere near barbed wire!!
Let's say I have at least 150 to 200 each hours, maybe as high as 300 hours on the weedwacker and the leafblower. Just a guess.
From almost day one I've been using the Pro-Mix synthetic from Lowes. It's the 2.6 oz per gallon that covers all ratios from 16:1 to 50:1. I've used it in everything from my weedwacker, leaf blower, chainsaw, hedgetrimmer, Tomos mini bike and my Trabant 601.
Then there are some oils that require more oil the stronger the ratio such as Lucas semi-synthetic. So 2.6 oz per 1 gallon for a 50:1 ratio and 3.2 oz for a 40:1 ratio and so on.
And of course Opti-2 which is a 100:1 ratio that covers all ratios. There does seem to be a difference between the Opti-2 and these other oils. The Opti-2 is sticky and is thicker.
I have put about 1500 miles on my Trabant 601 using the Opti-2 because I've used half a gallon of that stuff. I don't know how many hours that would be on a car. That car uses a 50:1 ratio.
Trabant Photos by turbofiat | Photobucket
I've read a lot of opinions on 2 cycle oils. One opinion is that ethanol is main killer of 2 strokes because the oil doesn't bind with the alcohol and the type of oil is not as important as the fuel.
What I'd like to know is how can some mixes cover all ratios where others you have to use more oil? And how can the Opti-2 say to use a 100:1 ratio for all ratios?
I'm not so concerned about my Poulan weedwacker and leafblower as I am my Trabant engine. I had another engine shipped over with the car from Hungary since I knew shipping an engine from Germany would cost out the nose. One guy says there are no more NOS crankshafts left although you can still build rebuild kits for them.
I go through A LOT of 2 cycle oil in my Trabant. Probably more oil since I got my car last September than I have used in my lawn equptment in the past 13 years. I'd like to find the best oil to use in it so I don't wreck my engine. But because I use a lot of it, would like to find a good oil but something in bulk. Such as Stihl 2 cycle oil in 5 gallon buckets. I have yet to contact the local dealer to see how much it sells for.
