1968 Toro Professional 70"
edwar355
I have a 1968 Toro Professional 70", I was wondering if anyone had any info on this mower particularly the reverse. Mine has two pulleys one off the motor and on for the drive system....push the lever forward and the belt tightens around the two and you go forward...pull the lever backwards and the two pulleys touch and you go backwards BUT both the pulleys are metal so reverse doesn't work to well. I figure there has to be some sort of rubber that goes around one of the pulleys but I don't know. I hope someone has some info on it and maybe a part number. Thanks in advance.
Here it is cutting 1968 Toro Professional Reel Mower 70" - YouTube
Please post the model and serial numbers for this unit.
chance123
Troy built uses the same type of system on some of their tillers for reverse
This one is going to take some searching, will get back ASAP, going to have to do some real digging.
edwar355
I've looked at all the parts diagrams but I still can't tell if the pulleys have a rubber grommet around them or not...or rather which one of the traction pulleys have a rubber around them. I've emailed TORO and still haven't heard from them yet.
sam.vilhelmsson
Hi
I am looking for a drive ball 3-8623 for Toro 70" Professional. Does anyone know how to retrieve on of these?
