My cub cadet just died?
CHARLIEBORG
What I got is the M60-KH (53CB5BDX750) (Tank) 27HP Kohler V-Twin OHV. My son was mowing my yard and it just died like someone trowed a switch on it? I be leave it is electrical. It had been cutting out while mowing last year some. I thought it was a fuel problem. Replaced fuel pump, battery, and some other ods and ends. Checked the 20 amp fuse, it's OK. You can hear the click when you have the switch on and pull up the PTO. SO I think it is getting some power. Just will not even click when you try to start it?
Try this troubleshooting procedure that I copied from others posts.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). *If you have power what is the voltage?
Fifth, check for power at the starter while holding the key in the start position (assistant again). *If you have power what is the voltage?
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
Thanks, I will get this done before asking too much more. It is raining here now, so It will be a day or so before I can check most of these.
Ok, update! Started checking things out with a meter and test light. Everything that should have power did. I even cleaned all the safety switches with contact cleaner to make sure all was getting good connections. Still no start? So I got to thinking about the starter and relay. Well both we're ok except I found a wire in the nest of wires that I assume we're there for test equipment to be hooked up to. But the one stood out because it was longer and looked out of place with the others. So I checked all the connections on the starter and one post was empty. So I took a chance, hooked up the odd wire to the post and it started right up! Guess it just cam unhooked while my son was mowing.
