Sounds like a spring came off. Look at the small pulley that the belt rides on it. It should have a rod on it that goes to the brake pedal and should also have a spring on it that goes to the frame.
Post your model number and I shall get a pic of it for you
I would guess a frozen idler pulley or pulley bracket.
