coachhenry1
Hello, I am new here and this is my first post. I have a Cub Cadet lt1018. I started it up for the first time this year and it started right up just fine. I then started to mow with it and it started to sputter and die. It started right back up without any problem. I thought that it may have been an issue with the fuel filter and the engine not getting enough fuel under load, so I replaced the filter. I also took the bowl off of the carburetor and cleaned it with some carburetor cleaner. I disconnected the fuel line from the carb and sprayed it out as well and sprayed the carb to clean it a bit as well. It appears as though when the mower rocks or his a bump (and my hard is pretty rough) that it begins to sputter. Any help would be greatly appreciated because I really do not like to pay the way over priced lawn mower repair man in my town. I really dont want to get behind on my 3 Acres.
