lonestarjeff
I'm looking for a replacement for my old(late '90s)Dixon 42" ZTR to mow our 2.5 acres. I wanted something a bit wider cut(48-54")in a mid-grade machine. The old Dixon was such a good mower I expected to get another one, but I soon discovered they're gone. The old Briggs Vanguard engine never stopped running either, but has become a booger to start(compression release stopped working). I didn't see Vanguard engines offered on anything current. I haven't read much good about the Endurance or Intek series so far, so I've narrowed my engine choice to Kawasaki.
My search covered lots of brands, but my budget ruled out the commercial guys. It came down to Toro & Husky because they have quite a few choices in the mid-grade....& the upper end of those seem to have commercial grade build. The 2 models above have the same Kawasaki engine. The Toro mower is about 100# heavier(700 vs 795), but has a little smaller rear tires(20" vs 22"). The Husky has the ZT-3100 drives(which is a plus), but I can't pin down what drives the Toro wheels. The Husky carries more fuel(5 gallons vs 3) which is interesting considering the Husky is lighter. The Toro has the heavier deck(10ga vs 12ga)& I believe the Toro deck is welded whereas the Husky is stamped....not sure what to make of this considering my old Dixon was a stamped 13ga deck & seemed more than adequate for all these years. Both have adjustable high-back seats w/ armrests & adjustable control arms.
In the end I'm leaning toward Husqvarna because of the larger tires & heavier grade drive units. The extra 4" of cut doesn't hurt either. They are both right at $4k, so price was not a factor between them. I'd rather have to spend less, but I couldn't find anything below it w/ the big tires & heavy drive units. My budget was $5k & with the bagging kit either mower comes in around $4500.
Having said all that does anyone have any negative or positive experience w/ these mowers? What about the bagging kits?
Jeff
Jeff
